Hi Mike,
I’d suggest you follow our S30 setup guide here: Setting Up Your SCULPFUN S30 With LightBurn - YouTube
The most common cause of diode lasers running into the sides of itself is a failure to home the machine on startup - which should be covered fully in the video.
Hey colin thanks for the reply… i did follow the video and came out with the problem.
When i hit the auto home button the laser wont even connect. . When i click it off it will connect.
Would it have anything to do with the stopping blocks
Maybe try to follow this guide and check if you missed any step: Setting up the software - Diode Laser Wiki
What do you mean here? Connection has nothing to do with clicking functions.
Are you seeing ‘Disconnected’ in the Laser panel on the bottom left? This would be a sign you have a comms problem. Go to the Console panel in the top right of LightBurn, what is reported there?
A screenshot would be helpful - https://www.take-a-screenshot.org/
