MySweety CNC-3018Pro 5500mW Laser won't burn
My laser turns on but will not burn on any material, including wood and cardboard.
These are the current settings:
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=0
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=800.000
$101=800.000
$102=800.000
$110=600.000
$111=600.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=200.000
$131=200.000
$132=200.000
I have the Fire button enabled and can see the laser come on and go off. The laser fires when you click start. Here is the Cut/Layers:
I just can’t seem to figure out why the laser wont burn/etch into anything.
Any one see where I might have a problem?
Thanks…
Those numbers are the maximum speed your laser is allowed to move. What units are your speeds in? If the 180 is in mm/min, I would expect that to leave a mark if everything is focused and set up properly. If it’s in mm/sec it’ll be too fast.
Also worth checking that the ‘S-Value Max’ parameter in the Device Settings is set to 1000 to match the $30 setting in GRBL.
The speed is mm/m. I checked the S-Value Max parameter in the device setting and it matches the $30 value. Both are 1000. It seems like the laser isn’t at full power even though I have it set that way.
Any other ideas?
I am beginning to think that the laser or the power board might be defective.
As a test, try changing the device to use GRBL-M3 instead of GRBL. That will use “constant power” mode and doesn’t care if you try to run it too fast - it will always output the power you ask for, but the quality of vector marking will be reduced (you get burnt corners).
I will try that but I think I might have found the problem. There is a diode on the laser control board that looks burnt.I will try what you suggested to make sure, but I am guessing I need to change out the diode. Or get (or make) a new driver board. Thanks for all the suggestions and help.
