NC files not working on controller (solved)
Hi!
I have just purchased a chinese CNC burner and a “offline controller”.
The controller is this: controller
From my PC, I can burn with no problem with LightBurn, but exported .nc files does not work with my controller.
For testing, I have created a single line with LightBurn and LaserGRBL and exported as .nc file: a line from 10,10, lenght 30 horizontal.
The one with LaserGRBL works (in the controller), but not the one with LightBurn.
Here are the .nc content:
The LightBRGL file:
M3 S0
S0
G0X10Y286.95
S66
G1X40F3333
S0
M5 S0
The LightBurn file:
; LightBurn 0.9.23
; GRBL device profile, current position
; Bounds: X-12.5 Y12.5 to X17.5 Y12.5
;USER START SCRIPT
$32=1
;USER START SCRIPT
G00 G17 G40 G21 G54
G91
M4
; Cut @ 130 mm/min, 95% power
M8
G0X-12.5Y12.5
; Layer C00
G1X30S950F130
M9
G1S0
M5
; return to starting pos
G0 X-17.5Y-12.5
M2
Any hint what is wrong?
The offline controllers do not like comments, and they require files with “Windows style” line endings, meaning (carriage return) + (linefeed), not just linefeed. You can use Notepad++ to do both of those things.
We’re planning on adding a switch to allow LightBurn to export for these offline controllers, but haven’t added this yet.
Thank you.
A temporary solution (I have to try it in the real controller) is load/save the file with LaserGBRL, as it removes the comments in the export file I have checked.
