Need assistance in laser power and lens size
Dear Friends,
Basically i’m new here as well as new in fiber laser marking, i’m having 50w Max source and 300x300 lens, it works perfect on aluminium, steel etc but dont work on copper sheet, if i user 150x150 lens with the same source then it works perfectly fine with copper as well, but after shifting to 300x300 lens its not woriking even after making 100% power and very very less speed, it feels like its not focused properly or power is not getting drawn but at the same time if we replace any other metal it works as expected, caon any one expert over here can suggest me what exactly i need to do.
Thanks In Advance
Copper is the highest conductor of heat. Aluminum is in second place. Funny that your fiber is strong enough for aluminum, but not quite for copper using the 300 lens. You do know the beam strength is MUCH more stronger with the 150 lens compared to the 300 lens, right? Did not do the math, but I would guess 4x stronger, maybe even more.
Not a fiber yser here, but I read lowering the pulse frequency increases the power. You might try that with copper and the 300 lens.
Other than the copper sucking the heat out of the spot area. The spot size is smaller with your F254mm lens than an F420mm.
F420mm lens, spot size or A = π r² = π × 0.025² mm² ≈ 0.0019635 mm²
F254mm lens, spot size or A = π r² = π × 0.015² mm² ≈ 0.00070686 mm²
Difference between the two is 0.00125664mm or about 1.2 microns. The F420mm is about 2.8 times larger in area.
There should be a difference in power by about 2.8 times. This is the same power your machine puts out, the lens makes it a smaller area, same power smaller area more damage.
If you look at an F100mm, spot size of about 15 microns and the F254, at about 30 microns. Changing from an F254mm to an F100mm makes for a 4 times smaller spot size, so it appears to be 4 times more powerful.. this is the lens, just like most lasers.
Are you sure about your focus? The F420mm has a dof of about 13mm, so it’s difficult to get it out of focus.
There isn’t a lot of manufacturers that specify settings for copper. Some guy on Reddit does it, but I haven’t asked him about any kind of settings. Might try a couple of his threads and see if he suggest settings.
Lower frequencies as @MikeyH suggested along with
https://www.reddit.com/r/Laserengraving/comments/1szgn2k/laser_engraved_copper_ingots_charlies_archangels/
https://www.reddit.com/r/Laserengraving/comments/1s892r4/new_copper_ingotbar_design_i_made_today/
https://www.reddit.com/r/Laserengraving/comments/1k0xv4e/some_copper_work_with_the_fiber_laser/
You can always ask them…
There are lots of charts that describe conductivity of copper and other metals.
:grinning_cat:
@jkwilborn is fiber user. He knows what he is talking about.
Thank you, this explanation helps a lot.
Yes, I agree that the issue is mainly power density. The F420 lens is spreading the same 50W into a larger spot area compared with F254/F150, so the copper is not getting enough energy density before it conducts the heat away.
Using your calculation, F420 area is around 2.8× larger than F254, so theoretically the machine would need around 2.8× more power to get similar effect. That means 50W is probably just near the limit for copper with F420.
I am also going to re-check focus, beam alignment, center-field marking, and try lower frequency settings as suggested. Since I am getting only very light marking at 100% power, 100 speed, 20kHz, 0.01 hatch, and 10 passes, it looks like either the settings need major tuning or the 50W source is marginal for copper with this 300×300/F420 lens.
Thanks for the Reddit links. I’ll check those copper engraving examples also.
I think 50W will work, but copper really sucks the heat away. Might want to go to one of the links I posted and ask him for his settings. I think he uses 100W, but you can likely get around that.
If you can find your laser source manual, it will tell you where it produces the most heat. My M60 JPT M7 MOPA advises about 45kHz for maximum output, if I remember correctly.
:grinning_cat:
