Need help, can't hardly see the screen
Does anyone know how to fix this? I downloaded LB to this new laptop but it is so small there is no way my wife will be able to use LB. I have deleted and downloaded it twice with no luck. After deleting I restarted the laptop.
Click on square in upper right corner
Thanks but the problem is the text is super, super small. How do you enlarge the text so a person can read it?
Should be in settings, the one with the gears.
Thank you Sir! That did the trick.
And, as always, migrate all the LightBurn settings:
