Need Help in Belize
Hello All
Need some help.
Was doing a job on my laser and in tyhe middle of the job I had a power outage for about 20 seconds. Power came back and my laser went crazy banging away on the x axis on one side. Now i am uanble to change the work area size and it keeps telling me “unable to connect to controller”.
Any advice on how to try to solve this issue.
This appears to be a grbl machine, not a Ruida. Probably be smart to edit the heading and change that.
When you power it up, it should home or sit there. I’m assuming it would normally home on power up?
If it’s supposed to home, I’d check switches first. If they are mechanical, I would look elsewhere if not ensure they work
If not it may have damaged the controller.
I have changed this to assist.
