# Need help in getting Monport GM 60 watt Mopa Laser and Lightburn working
**URL:** <https://forum.lightburnsoftware.com/t/need-help-in-getting-monport-gm-60-watt-mopa-laser-and-lightburn-working/167458>\
**Created:** [March 11, 2025, 11:33pm UTC](https://forum.lightburnsoftware.com/t/need-help-in-getting-monport-gm-60-watt-mopa-laser-and-lightburn-working/167458 "2025-03-11T23:33:43Z")\
**Showing post:** 1
**Author:** ![RCGunsmithing](https://forum.lightburnsoftware.com/letter_avatar_proxy/v4/letter/r/e0b2c6/32.png) [@RCGunsmithing](https://forum.lightburnsoftware.com/u/RCGunsmithing)\
**Post date:** [March 11, 2025, 11:33pm UTC](https://forum.lightburnsoftware.com/t/need-help-in-getting-monport-gm-60-watt-mopa-laser-and-lightburn-working/167458/1 "2025-03-11T23:33:44Z")
I have a Monport GM 60 watt Mopa laser and trying to get it set up with Lightburn Pro but having no luck. I will be using this to engrave gun slides so I need to be able to see where the image will land before engraving. First, the system doesn’t seem to be framing properly, one minute it’s showing the red frame then the next it won’t come up.
Second, I got the Monport to engrave one time and it did fine and then the next times I tried to engrave with the settings set at the same thing, it did nothing but a light marking that you can wipe off.
Currently I’m running the Power at 80 the speed at 750 and the frequency at 100. I have a 3 layer lightburn stacked file for the clean pass, image, then another clean pass.
I’ve installed everything correctly from what I can tell but still it just won’t work properly.
Any help is appreciated.
_[View the full topic](https://forum.lightburnsoftware.com/t/need-help-in-getting-monport-gm-60-watt-mopa-laser-and-lightburn-working/167458)._
