Hi all and thanks for the help. New laser user. I have tried to read every thread and youtube video. I have since tried to align the laser head to square. I created a square on the boundary f the cut area and it is not a square. I have ran it with every different bulge setting changed and it is still blown out.
You can see in the pics how the square is convex. How do I fix that.
I also seem to have issues when trying to cut on the far outside. It is either curved, even though the design is straight or it just skips the area all together.
Your machine should have come with an alignment file, usually something like markcfg7
Lightburn will allow you to import it when you create a new device. You can also edit the current device, what you don’t change is retained.
The other option is software that come with EZCad2, can’t remember, but doing it manually is an issue. Double check for that file on the usb stick that came with it.
Mine was here on the stick
LMA22A1095JZ/Ezcad2.14.16/plug/markcfg7
Might watch this video… uses the supplied EZCad2 software to adjust this…
Thank you for the reply. I knew I watched a vid how to fix it, but couldnt find it again. The supplied usb from Omtech when inserted set of every anti virus software on the computer. There is no reason for a clean install of ezcad to do that so I clearly didnt use anything on that USB. I will reach out to omtech again for a clean usb.
