Hello, I’m new here, and also new to the world of laser engraving. I have been doing fine, but my X axis is flipped in LB, so I after I create my design and before I send it to my machine, I have to Flip Horizontal to get it to show up correctly on my control panel.
Why is this happening and what can I do to have my canvas in LB match the actual table coordinates?
To even further explain, for example, the design will be in the upper left corner in LB, but when I Frame on the machine, it places the laser in the upper right corner. If I don’t Flip Horizontal, by design will come out flipped the wrong way. The Y axis seems fine.
This is the origin corner or 0,0 location for your laser. If you have a GCode based system, this is almost always at the front left, regardless of the location of your limit switches.
If you have a DSP laser, like Ruida or Trocen, the origin is usually where the limit switches are placed, and will will be the corner the laser seeks when powered up.
If your laser output is mirrored horizontally or vertically, move the dot to the opposite corner, horizontally or vertically, depending on the direction that the output is mirrored, and that will correct it.
