Need to cut each shape in an array multiple times before moving to the next
Hi.
I know this is a beginners question but I am trying to find an answer.
I create a square.
Then I make an array of 20 of these squares.
But what I need to do is after each square it will repeat that square several times before moving to the next square.
Everything I do gets Lightburn to do All the squares, and return and do all the squares again.
Any words of advice
Dave.
It’s strange and I can’t see how it changes with “cut”, here it is standard that the shapes are processed individually/finished before moving on to the next item.
With “fill” we have the 3 known options to determine how we process the different items.
Can you send a small lbrn2 with an example?
here is a preview with an example of my test
Are you using Sub-Layers or multi-passes?
For what you’re trying set the cut to desired number of pass.
Hi.
Here is the small file.
Blank.lbrn2 (58.0 KB)
What I would like to happen is that it does each blue tablet twice, and then moves to the next one. The same with each red dot or box.
Unfortunate what ever I do LB wants to do all of the blue, then return and do it all again. not treat each blue tablet as a seperate entity.
I have small pegs that raise my work 3mm off the honeycomb so not to get scorch marks.. but if a shape has cut and dropped down I can pause and retrieve it so it does not get marked by the next cut.
Many thanks
Dave
There are so many open segments and nodes in your blue (C01) layer that it was much faster to make them from scratch.
Now you can cut/engrave the innermost shapes from C02 (red) first and the frame afterwards with as many passes as you want and one at a time
There is no need to use multi-layers for this project.
Time should be saved with “remove overlapping lines”, but I have not tested that.
Blank-retur.lbrn2 (23.5 KB)
Many many thanks for this :slight_smile:
When I have a full sheet of these (54) it makes it a lot easier to ensure each one is finished before moving to the next one.
I did not realise that I had these open segments since I had joined and grouped them all together
Again many thanks. I will have to updae all my library of finished files with the new shape.
Dave
