The spec that came with my machine does not give the watts, all it says is 24V 2A in power supply. Can anyone please work out what the watts are. (see Attached. Thank you.
“Electric power is given by the formula: P = V × I where is the voltage measured in volts (V), and is the electric current measured in Amperes (A).”
Easy math… 24v x 2a = 48w. This is less than the average notebook computer.
This suggests you have a 5 watt (or less) output power laser module. My 10w machine has an 84w power supply.
Thank you so much.
5 watt is de laser power
Thanks peeps
