Making a jig to engrave 25 coasters at a time but engraving is taking a lot of time traveling between coasters from one side of the tray to the other. Is there a setting where I can engrave one coaster at a time and then go to the next, eliminating the excessive travel time?
Perhaps selecting Fill Shapes Individually will help:
In the Laser window, there’s a button for Optimization Settings.
You may also want to look at ‘Reduce Travel Moves’.
Group everything on one coaster, then Array it into a bunch. Fill Shapes Individually will do them one at a time. Sample Lightburn file attached.
Coaster Process Pattern.lbrn2 (176.4 KB)
In addition to all the other tips, when I’m doing a full tray, I’ll use the Shape Properties window to assign Cut Order Priority to each coaster.
The other tips can help with doing one coaster at a time before moving along, while Cut Order Priority lets you manually order the coasters into an ideal sequence. Not only can this save some time, but it also means they go in a logical order with no skipping around, which means you can easily keep track of where you are in the overall job.
(I also appreciate it for partial trays or resuming starting at slot N, as that’s easily followed when the order is fixed.)
