Needing to find laser each time I setup
Hi, I have a Sculpfun S6 Pro and each time I setup the laser fails to respond to commands, I find the only way to make it work is to go through the find my laser process again.
In what order do you plug things in and turn them on?
Some USB ports are powered full-time even with the computer off.
Do you have a dock for your laptop?
You may be able to eliminate the Find My Laser by adjusting your order of operations slightly.
