For some reason my negative button on the cut settings stopped working. Any idea why?
Here is a screen capture:
Here is the other layer cut settings to compare
Are you expecting the on-screen image to show as negative when you do that? I haven’t worked enough with this to know if this behavior was different previously but I can confirm that my on-screen view does not change view. It matches yours.
However, the preview does show a negative and “Adjust Image” also shows the negative image.
I suspect the image will also burn as a negative although I haven’t tried it recently.
You need to enter the preview window and set it to invert.
The image will only be inverted when previewed or sent to the machine.
OK, thanks guys
