I updated the firmware of my Neje 3 via Win-Software to v1.0.4. Also updated Lightburn to the newest version. Since than I have issues with object cutting in Lightburn. All forms are incomplete cutted at “as it seems” start-/endpoint.
I tested the gcode from Lightburn also with gcode-simulator (g-code simulator). When I try to make same objects with LaserGRBL I don’t have any issues and get clean cuts(!!!)
I would be thankful for any kind of help because this is very frustrating! I am sure now the problem must be Lightburn…
I don’t see anything wrong with the g-code. Can you try running this g-code in LaserGRBL? I’ll assume the results are the same but please confirm.
Can you separately generate g-code in LaserGRBL and post here? I’d like to see what the difference might be. I initially thought it might be an issue with G0 rapid speeds but that wouldn’t account for the gap within the shape.
