Is this one
The one I purchased on Aliexpress is no more available. It did cost me 26€: HAILEA electromagnetic air compressor, 6-way air aerator pump, for fish tank, Air pump, oxygen, hydroponic, 45W, 70L/min
You got the 328? Mine is the 318
My machine was supposed to be a 2021 model, whatever OMTech means by that. It did come with a honeycomb bed and a compressor very similar to the one posted by @killrob. The ones I used to see where mounted on the side of the case (my bracket is still there) and looked like they were made completely of plastic. Don’t know which model is in mine.
So it was an ‘upgrade’ I guess. It was $12 to replace the honeycomb from the local steel supplier.
Now that I’ve moved, I will finish hooking up the home compressor and dump the supplied one… I usually use the home one when I’m cutting, which I limit.
Good luck, take care…
