Hello all
I have a NEJE max 4 laser with the extension of the size (1030x750mm).
In the original program of Neje I can control the laser without problems and send it to the right position.
In Lightburn the X axis works without problems but the Y axis does strange things.
For example, if I move my drawing +400 mm down in the Y axis, it does not go down but the laser goes up into the wall/mount or somewhere else.
The home button works without problems and it goes where it needs to.
But somehow it has problems with the Y axis…
When I laser a square, it has the correct size.
So the Y axis steps from the motor are correct.
Does anyone know this problem?
Thank you very much and best regards
Dominique
