Neje position VS Light burn grid?
I have just setup my NEJE 7w with Lightburn. All is connected and running. My problem is laser location VS the Lightburn screen. I can’t seem to get the direction of travel coordinated with laser position. With the laser in its home position (top left at the control board. Device setting top left for the origin. Up and down are reversed when I use the move keys.?
Front left is the zero position with nearly every GRBL set up, not rear left. Power up the Neje with the laser in the front-left and set the device origin to that corner as well.
Looking at my laser The main beam is vertical with the control board at the top. The narrow arm is to my right with the laser closes to me.
Ok With that orientation all is well. The rest now requires me to spend time with the tutorials and software
ThankYou!
