Hi, I’m beginner, trying to get my NEJE Master 2s Plus 40W working together with my MacBookPro (Mojave).
Unfortunately, at the moment (and for some time now) all NEJE-related websites cannot be reached, so all outbound neje-links in this valued forum are not working.
Specifically, I’m searching for advise to fix
-the “mirrored output”-problem (horizontally flipped, upside down), as well as
-the (missing) precision of lines and
-some power adjustments.
I found some worthy information here, yet not enough, since outbound neje-links seem to be dead / broken or the sites may have been taken down.
So, self-help. Is there some experienced expert-user here that would be willing to provide some basic settings or helpful setup-instructions?
Thank you in advance for your patience, and kind regards
triple-check your belt tension. Make sure belts are taught but not stretching.
You will need to experiment with this based on material, your lens, and laser power. There are various test patterns you can find in this forum to help you.
