light burn works fine on neje 3 but nenje master 2 will not connect or work on with light burn no matter what i try. .done evry thing forums suggest no luck.
is it compatible at all with the master 2. any help will be appreciated
thanking u kindly
max geyer
Yes. It should work.
Have you seen this?
nejelaser_master_2 | NEJE.wiki (nejetool.com)
If your laser is currently running the Benbox software it won’t be properly compatible with LightBurn. You would need to convert to GRBL firmware.
