Nestbolt: free, open-source nesting in the browser, now with LightBurn project support (preview)
I’ve been building Nestbolt, a free, MIT-licensed nesting tool for people who cut fixed sheets: laser, CNC, plasma, waterjet, fabric and leather. It runs in your browser at Nestbolt: free nesting for laser, CNC and fabric, in your browser. The engine is compiled to WebAssembly and runs on your computer, so your files are never uploaded and there’s no account. I built it with a lot of help from AI coding agents.
With LightBurn projects (a preview feature, so please tell me where it breaks):
  • Open a .lbrn2 or older .lbrn file. Each group nests as one rigid unit, so ungroup the parts you want placed separately.
  • Download one editable .lbrn2 per sheet. It keeps your layers and cut settings, text and images. You can also put the sheet outline on a tool layer.
  • Shapes on tool layers, or with output turned off, stay where they are.
  • Text and images are nested by their bounding box, and the original artwork stays as it was. Older text may need one save in LightBurn first so its outlines are embedded. If a group mixes output-enabled and disabled shapes, regroup it first.
With SVG or DXF: lines, arcs, Béziers, splines and blocks are converted to millimetres. Each closed outline is a part, and the outlines inside it are its holes. You get one SVG and one DXF per sheet, made from the original curves.
Nesting: fixed sheets with margins and spacing, several sheets and stock sizes, defects and remnant outlines. Rotations can be free, stepped, or a list such as 0/180 for grain. It can mirror parts, and it puts small parts inside the holes of big ones. Every result is checked by an independent validator, and invalid layouts are never returned.
On the project’s frozen benchmark, with equal 60-second budgets, it used less material than Deepnest on all 55 jobs where Deepnest produced a layout (median 9.9%), and less than SVGnest on all 36 (median 14.4%). Every per-job number is published on the project’s results page. Those figures are for the frozen v1 build. The hosted app runs a newer preview that hasn’t been re-benchmarked.
It’s built on jagua-rs and sparrow by Jeroen Gardeyn and collaborators, whose sparrow/studio was posted here in September. The difference is that Nestbolt fills fixed sheets, several of them, instead of a strip. I haven’t compared it with True Nest, so this isn’t a claim about it. It’s a free option if you’re on Core or nest outside LightBurn.
Source, issues, and a short guide with the settings for laser cutting (linked from the README): GitHub - skulitom/Nestbolt: Free, open-source 2D nesting for fixed sheets: laser, CNC, plasma, waterjet and fabric. SVG/DXF in and out, part-in-part, several sheets. Runs in your browser (nothing uploaded), on the command line and as an MCP server. Built on sparrow and jagua-rs. · GitHub
What helps most: projects that fail to import, or layouts that look worse than you’d do by hand.
