Nach dem Update sind die Laserleistungen geringer als vorher.
der Feuer button geht,lüfter geht an aber kein Laserstrahl/Punkt.
Ortur Master2 lasert aber man sieht keine Ergbniss auch bei voller Leistung nicht. Update s******
After the update, the laser powers are lower than before.
the fire button goes on, the fan goes on but no laser beam / point.
Ortur Master2 lasers but you don’t see any results even at full power. Update s***
Instead of throwing something incoherent and insulting into the room, the next time you can try to ask properly if someone can and wants to help you. If you also translate that into Google translate yourself, so that others don’t have to do your work too, you may have a chanse to solve your problem.
