New button (or File-> menu item): Open new instance
Hello,
I often use more than 1 instance of light burn at once. Often it’s just to open another project and copy something from it, other times because I (admitedly quite poorly) multitask multiple projects.
But the way Windows is setup, openning a new instance of lightburn require a lot of clicks and/or typing. And openning new instance is something I do… A LOT lately.
Would it be possible to add the possibility to add a new optional toolbar, which contain just a button that open a new lightburn instance?
I’m sure this is an extremely easy and quick feature to add, and if there was plugin system; I’d look at making one myself :slight_smile:
Thank you !
How are you doing this today?
The easiest method for creating another instance in Windows may be to hold shift key while clicking on the open LightBurn icon in taskbar.
Oh! I did not know that. That solves my issue completely!
Thank you so much !
