New error message on Ortur Laser Master 2
Lightburn version 1.0.04
Windows 10
Everything has been working fine for months. Today I am getting two new error messages.
Waiting for connection…
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2]
[OLF: 140]
[DATE:13:36:28 - Dec 31 2020]
[VER:1.1h.20190903:]
[OPT:VNZHI,99,254]
Target buffer size found
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Ortur Laser Master 2 Ready!
OLF 140.
Grbl 1.1h [‘$’ for help]
[MSG:Check Limits]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
AND this error message:
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
OLF 140.
[MSG:Check Limits]
ok
Can anyone point me in a direction to figure out why this is happening? Any help is appreciated.
Not sure this is the solution, but sounds like $130 $131 are not set to the correct bed size.
