I have a new Longer Ray5 laser cutter and LightBurn software.
The system will frame the letters to be cut OK and the Laser will register the cutting mark point by a blinking light, But it does not cut the pattern.
Brian Krupicka
I’m not clear on exactly what is happening. Is your laser moving and firing the laser but not cutting through or is it moving as if it’s cutting but not firing?
If it’s leaving any mark on your material, can we see a photo?
I would check that your laser is focused on your material, then slowing down the speed and slightly increasing power.
thank you for your replay
The PASSES were set to one i needed to up it to 10 to work.
