New laser - new origin
My wife recently received a Roly LM2 10/30. She has been using an Xtool D1 Pro 20w for about 18 months. Naturally, all of her designs were created in and for the D1 Pro. She’s been trying to find an easy way to convert her designs into the Roly layout as it’s home position is front left vs the Xtools back left. She’s tried mirroring, but that isn’t working reliably. Is there an easy way to do this without a lot of redesign work?
Try changing your origin.
Thanks for your help with this. I did set this when I added the Roly to her computer, but when she opened an existing design it was upside down and backwards. I checked other files of hers and they all appear to be fine. Not sure what may have happened. She’s doing power and speed conversions now for the 30watt.
That’s because it was created with a different origin point. Just select all and rotate/mirror as necessary and when she saves it from there it will be correct next time she opens it.
Tim - thanks we figured it out. Thanks for your feedback. When she added the Roly, she didn’t check the origin so everything had to be flipped. All good now.
Thanks again.
Tom
