Hi all. I just put a new lens on my 50w fiber and trying to set up. I followed the LB instructions, but the square is not square. The height is correct but width is not. Any thoughts on what I do to correct this?
If you have followed these instructions and calibrated your new lens then I would suggest adjusting the red dot alignment.
THANK YOU THANK YOU
Forgot to adjust basic settings.
Actually I had done this on my first attempt but the square ended up distorted so I deleted and started over.
Now the square is fine but everything is upside down and backwards.
This happened when I first connected the laser to my laptop and I do not recall what I did to correct it.
DO you have any idea?
Glad that is sorted.
Correcting the output is all done within the device settings
Change what Galvo is x axis then use the reverse direction slider if necessary
Thank you. I think it is all set now.
