Hey Guys , ( at first sorry my English isnt that good i am from Austria ) i really need your Help
I just got a new DIY Chinese Laser with a Arduino CH340 Board. There are two Problems which I can
The Laser drives to the wrong Direction i i press the left Button the Laser drives right , if i press the right Button the Laser drives left. ( i cant change the Slotplace on the Board ) is there mabe a Option on Lightburm where i can Change this ?
Is there an Option where i can but the Laser on very weak Strenght , and then press the Frame Button to see if the Laser is on the Right Position ?
Welcome. This sounds like you have the Machine Origin set incorrectly in LightBurn. This is the origin or 0,0 location for your laser. If you have a GCode based system, this is almost always at the front left, regardless of the location of your limit switches. What firmware are you using to drive your laser?
You can click the to expose the âDevice Settingsâ window. Where is this currently set?
Ok, thanks for that. Please re-post a picture of the console window where it shows the grbl version. You can scroll that window back up to the beginning messages of the connection. I also want you to post the entire results after you type $$ into the console and hit Enter (return). This $$ command will list out your current firmware settings.
Ok, so that isnât GRBL - itâs âBenBox Laserâ which is a custom version that doesnât support all the commands. And it is from 2015, so if you can find a proper version of GRBL it will work much better. I suggest you can flash your controller to grbl 1.1f or later and then select GRBL in the LightBurn device setup.
