[OPT:VMHL,15,512]
Target buffer size found
ok
Homing
<Idle|MPos:0.000,0.000,0.000|Bf:15,511|FS:0,0>
Starting stream
Layer C00
ALARM: Hard limit
On or near line 19:
Job halted
Stream completed in 0:00
[MSG: Reset to continue]
Everything I want to do is out of bounds, I wish i could just reset original settings… Thank You for you help. Bobby
I suggest you switch to “Absolute Coordinates” in Start From pulldown in Laser window. Unless you have a workspace defined larger than your work area you should never run into this while using Absolute Coordinates.
Will Do, Thank You
