New update issues
The one on the top is a previous burn and the bottom is one i tried last night
If it’s not the same file, on the same wood, it’s not really a meaningful comparison unfortunately. It’s also possible the diode itself has died - they do have a lifespan, and if you’ve been running it for 8 months, that’s unfortunately a possibility.
Do you have other software that you can try it with? (whatever it came with, for example, just to rule that out?)
let me find one where i used the same file and it is the same kind of wood on both
This one was using the same file the image in the top corner was added later
No this is the only software that i have. any suggestions?
When was the last time you cleaned your lens, or checked the focus?
I check the focus before i use it everytime. How do i clean the lens and i will give that a shot
Water or a bit of Windex on a q-tip. Isopropyl alcohol works well too.
Where did flood fill go on the update?
Where fewer people can find it accidentally. :slight_smile:
Click the ‘Advanced’ tab in the Fill settings.
Thank for all of your help! I finally have it back up and running!
