New user, z problem?
Hi, so I’m new to MillMage, I’ve been using a different program for a while… I just started trying to get my machine a Genmitsu 4040 Pro working with this though and I can get it to home, and frame correctly, when I go to start a job the machine moves to the start point of the project, plunges 15mm into it and stops dead :frowning: I’m a little confused what’s happening because the start depth for my pocket is set to 0mm and my final depth is 10mm, and my depth of pass is set to 1mm, I’m zeroing at the top edge of the workpiece… any suggestions on what I could be doing wrong in the software to cause this? anything I should check that I might be missing? I would attach my mage file but I don’t see a way to? so if there’s a way to do it I don’t see let me know… thanks.
