New version 1.4.04 causing issue with cutting that weren't there before
The new version is taking multiple passes to try to cut through 1/8 inch and 1/4 in plywood. Had no issues before this update. No matter where I put the settings it’s just burning the wood and this was not an issue before. OMTech 100watt with a Rudia controller. Does anyone know of a fiux for this issue?
Do you specifically mean 1.4.01 or are you referring to the most recently released 1.4.04?
Neither of these is likely directly related to the issue you’re seeing in any case.
Confirm that the speed and power settings are in fact what you expect them to be. Also check Min power setting.
Then confirm that the speed and power settings are reflected appropriately on the Ruida panel.
