New Version resize taps
Have not been able to use the last two updates due to not being able to adjust size of taps. Size arrows show but don’t do anything. Not able to see bottom of tab. Ideas.
If the issue is that you cannot see the bottom of the cut settings editor page to click the OK button, you can just use the enter key to accept changes and the esc key to cancel. There is a known issue with lower resolution screens and they are working on a fix.
You can also try using WinKey+UpArrow to maximize the window.
