New web tool experiment added a Prusa Slicer to autobuild layers and true 3D viewer
What started last Sunday as a experiment, is actually running. I was curious to see what it took to build on LB/MM and Prusa API web tool. Really like this new ability in LB/MM to add tools a user can design. What this does is you open new project, import a image, then hit webtools and excute this tool, it pops a web page from LB/MM and then does something I have not seen before. It grabs the current image, converts to grayscale, then autogenerates via Prusa Slicer API, layers with a matching default operation assigned. Each layer has a Z range, and its organinsed to divide total Z by number of layers which is the grayscale range of the original image. it has the ability to apply contrast, brightness, gamma, set up auto layer alignment mark for easy tool changes, adjustable ranges of layers from 1-256 for lasers, and 16bit for CNC that are closed loop and have 1 micron resolution. (Note most CNC’s and lasers are .1mm resolution and the materials and tools required for higher resolution are much more complex discussion). It also has a very cool viewer that works with mouse or Nintendo Switch game controller via USB. makes tweaking layers and view really fun. How was this done Google Gemini in 3 days. Still learning a lot about API, CNC and Lasers. One thing to know is I used slicer to invert the gcode order. CNC and Lasers cut, 3d printers like CoreOne deposit layers. The math however is the same. We just in mill mode work top down vs 3D printer bottom up. would be interested in talking to other developers and LB/MM to learn more things we can play with.
Update on CLE. I’m not good at these videos, but it should help explain what this is.
Comments and suggestions greatly appreciated as I stumble in the dark experimenting with Web Tool feature in LB and MM. Thanks to those who have helped, to Prusa, JumpStart 3d, and Lightburn making this possible. This was done in 80hr with Google Gemini Pro.
J
Starting to document MM/LB for CLE. These are first drafts. double click to open. Please share comments I am new to this and value your thoughts. J
have a look at screenrec to record your videos :slight_smile:
nice idea thanks for the tip J
havent got throught watching the whole video , but looks like something that would be useful for me , have clicked on your google link , just waiting on you to respond to it
Cheers quick update. For those interested here is link to github for this experimental project for Mm and LB. CLE has added Vellum in addition to jumpstart 3d. This is alpha so expect bugs and things that do not fully work. were only about 100hrs into this project. We have a 2nd JSVCLE which is standalone as well. GitHub - jbirdlebough1/CLELBMM: Continuous Layer Extension for LightBurn & MillMage - Experimental CAM Web Tools Integration · GitHub
The standalone is JSVCLE. We will be running in to walls for some time. We encourage folks to share their customizations that helps everyone learn more. Thanks to all that have contributed. Will be interesting to see how this develops.
J
