Newbie in need- shapes cutting incorrectly
Hey everyone, just got my fox alien LE 4040pro 20w set up and was messing with some simple shapes (photos attached). Laser seems to be working however it has cut a completely incorrect shape (size is okay). Is there any settings I can change to remedy this- I’ve already fiddled with the speed/power settings. TIA
This is not a settings issue, but a build issue. Most likely you have belts that are loose, or something else in the motion system that isn’t correctly assembled, has a loose bolt, etc.
Appreciate your help Oz, turned out to be the belt tension as you mentioned. Easy fix!
