Newbie needs help....circle turned into an oval
Hi there,
I am hoping someone here can help me or point me in the right direction on what I need to do. I am working on a project and I wanted to cut 4 circles. During my prototype, the circles were fine on the first run. I saved my project, shut my laser off, and started it back up. I highlighted the things to cut and this time instead of cutting circles it cut ovals. I am using an Azter P20 if that helps. Just to recap I cut the circles, saved the file, shut the laser off, turned the machine back on then it failed to cut circles.
Thanks in advance
A common cause for this is that you’ve enabled rotary in LightBurn. If so disable and this should be resolved.
I will go and make sure I did not accidentally enable it and report back…
Berainb,
You were spot on. I much have hit it when was doing a horizontal align…thanks for the fast help!
