Newbie questions
I’m just starting my new venture. How do you set up or where do you get your line mode color square usually located at the bottom of lightburn users screen. Thanks for your help. I have been in the computer world for years but am stumped on this little question. s_o
Hi Sheri,
It’s called the color palette.
you will find it under Window in the top menu bar.
Cheers,
Rob H.
My cut pallet it checked but nothing is visible. It shows up on the computer, and another, but on one of them it is not showing. please advise.
Try window > reset to default or try different screen resolutions.
Just wrote this in another posting…
That means you do not have enough window real-estate. You can switch to a higher resolution in Windows, if what @berainlb suggests does not work, (harder to see) or use another computer.
Of my three laptops, I had the same problem with one of them, and all 3 have the same size screen. The i7 & i3 Dells were good, the i5 Acer was not. It is not a Lightburn thing.
An option is to add an LCD monitor/TV with HDMI input as a second display. These are fairly low cost on Amazon these days.
