No fill render with install of 1.2.00
Just installed 1.2.00 and fill does not seem to be working. I do not think I changed anything that would cause this issue.
no fill.lbrn (2.9 KB)
Found solution, Under Window I need to select Fill/Smooth.
The default and our recommendation is to work in wireframe mode to avoid the potential of covering something behind another when using filled rendering. Glad you found what you are after. :slight_smile:
