No fill selection options on lightburn that isnt attached to laser
I need to prep files on a pc that is not attached to my laser because traveling to the site to prep them would be a waste and when I am there I need to be using it not prepping files. However when gauging time estimates I can never get a good read on “fills” because it wont let me do “fill each shape individually” or “fill groups” it ONLY does fill all shapes at once which for some projects leads to massive estimation times. I need the correct estimation times to book time for the laser.
Turn off beginner mode and see if that solves your issue.
Thank you I had no idea the was a “beginner mode”
The next time you’re there, export the LightBurn configuration and import it into your PC so all the other settings match:
