No machine listed in pop up and window will not allow me to type anything
When lightburn ask to check the laser you are using - laser not listed and will not let me type or list laser that it is connected to.
Light burn launches and says laser is ready but when prompted laser does not react to any commands
Correct. LightBurn talks to the motion control system used and knows little, if anything, about complete laser system brand names or the supplier name.
The key bit, the control system used and the firmware used to drive the system.
Please start here and walk through the installation and set up process described within: Home - LightBurn Software Documentation
Then, let us know how you are progressing and where in the process you are finding issues.
You might need to install a driver for your machine - have you used it with any other software before, or is this the first time?
