I’m trying to set up a material library. When I check the library window I get nothing.
There is no material library by default, you need to create your own. Documentation is here: Material Library - LightBurn Software Documentation
My problem is a tab or window for the library doesn’t open when I check it. All the other ones work except library.
Can you attach a full desktop screenshot with LightBurn maximized and the Window menu opened?
What version of Windows are you running?
Okay so… I started my computer, windows 11, to get the screen shot. This time when I started the program there was the window for the library. Crazy. Thanks for the suggestions.
Although not as exciting, the best fixes are the easy ones.
