hola de pronto mi S30 pro no movio mas el eje Y y se queda pegado, que psria ser?
Hello, suddenly my S30 pro didn’t move the Y axis anymore and it stays stuck, what could it be?
Sculpfun S30 Pro?
Do the Tilt Test outlined in the Sculpfun Assembly Manual. Does it move freely when you tilt the frame?
As Mike suggested, do a mechanical check first (some tips: Guide to mechanical adjustments and maintenance).
If this doesn’t help, exchange the x and y motor connectors and check if the error moves with the cable. Then it’s probably a connector problem.
