I am trying to setup rotary. I have enabled the rotary, have rotary setting in the Tools Menu but there’s nothing under Machine Settings.
I watched a few videos by MW Laser and unless he has a different version of Lightburn, he has the rotary setting in Machine Settings. I am using the current version.
I am setup to use a GRBL laser but don’t know if that could be the issue.
I am using a Demon Controller with a rotary switch.
Every different controller will have different machine settings. In your case, the controller itself does not manage the rotary, LightBurn does, so you’ll find the rotary settings in Tools > Rotary Setup.
