Node creation and manipulation
I create a box, convert it to a path and create a node between one of the sides of the box. To create the node I go to node editing and press the I key at the location I want the node. A small red box is created. I want to cut the segment of the box between the just created node and an adjacent corner. When I select the scissors tool, the node I created disappears and I can’t cut the segment.
Please help.
Show us an example, otherwise it will be difficult to help.
Hover over the line you want to delete and press “D” with the node edit tool selected. I think the scissor tool is when 2 or more vectors are overlapping.
Yes that did it, thanks so much.
