Node duplication problem
When you draw a line let’s say from left to right then go into nodes and click on the left nodes it moves ok but the one on the right always stays where it is and a new node is produced, how do I stop this happening
Thanks in advance
Tony
I don’t think I’ve ever seen this behavior. What version of LightBurn are you using?
After weeks of struggling with it I posted on here then went back on lightburn and sorted it !!!
So just on case there’s any other idiots like me …
What I was doing is ending the line by clicking the space bar which does work if you don’t move the mouse, even the slightest movement of my mouse was making lightburn draw another line because it was such a small line the end node from it was appearing on top of the other.
Motto…don’t use the space bar to end the line use the escape key !!
