Hey guys, i have posted about this one before. Every now and then node editing is not fully working. In particular, i can’t break, delete, and insert nodes. Every other function is possible. After a few reboots of lb this was fixed on its own. This time it didn’t and also i realised that every time it happens, docking takes a long time to complete. When i press the docking button lb almost crushes. This happens regardless of the pc i work on. I will attach the file for anyone to try.
box.lbrn2 (45.5 KB)
Funny thing, once i posted it fixed…crazy…
… so just write when you are in trouble - if that is enough for the problem to be solved
But seriously, it would always be nice to know the cause of a given problem. However, it is rarely possible when it is not reproducible.
I know, so far i had no problems using lb.Only this happening in the past few months. I haven’t concluded whether it is my issue, but i try to give clues in case anyone has experienced something like that too. After all it is designing time wasted when it happens. Thank you though.
It’s obviously not good, I’m just wondering if the 2 minute interval backup function LightBurn doesn’t give you a certain recovery option of your work?
LightBurn is not error free and a lot of work is done to make the program as stable as possible, but finding “periodic errors” is a difficult task.
I get basically same problem if I use a lot of node editing. After a while things start slowing down and joining nodes seem to get more difficult. I saw where this issue was addressed in an earlier version, but problem seems to still persist. Just takes longer before I start having problems.
