I create a square, deselect the square then re-select it. I click the nodes icon and no nodes show.around the square. I use the offset tool to create another square and those nodes show. Help.
Thank you. What is a path and how is it different than a vector created with the create or draw tools?
This article should help. The built-in shapes are not paths natively and must be converted for Node Editing.
Ok thanks, I think I’m getting it. It also seems that if you use the Boolean assistant to merge two shapes lightburn automatically converts the shapes to a path.
You are right. That explains why I sometimes I had convert the primitives.
