Not completing cut
All of the sudden my laser (XtoolD1) is not completing the cut, (sorry, only way I can think to describe)
not cutting
Note on the circle and the heart the red lines, move between cuts.
Do you have tabs/bridges enabled in Cut settings?
I think I may have fixed it. Restored to default
You can see in the screenshot that “Tabs / Bridges” is enabled. That is likely what was causing the issue in case you run into it again.
