Not cutting or engraving what I send to laser
I have had my 100w Omtech for around 8 months and this is my first problem. The laser is cutting and engraving strange lines and where it shouldn’t be. Everything is clean and aligned. I have cleared the laser controller of all files. It is happening on files I have used many times, and also new ones.
IMG_1263
Might be loose belts. Do a mechanical review and check that belts are taught and that pinions are well secured.
Yes everything is tight and clean and lubed. I’m thinking it’s a problem with the communication from lightburn to laser. Maybe something is corrupt?
It’s possible but unlikely, especially if you haven’t had problems previously.
How are you connected to the laser?
Let’s eliminate communication from the equation with a test. Try this:
  1. Save .rd file to a flash drive
  2. plugin flash drive to controller
  3. run job from flash drive or copy to controller and run
Does this eliminate the issue or does it persist?
