Not Engraving 1st Timer
Went out to play with it again - connected LB - hit start and again the laser moved but nothing was engraving - I stopped the program on my lasers control pad - noticed the file from LB was on my controller screen - hit enter and looked at the parameters on my controller-it showed cut max power1 was set at 20% min power1 was set at 20% and max power2 was set at 0% and min power2 set at 0% - I changed these both to match power1 settings a it now is engraving. - honestly know nothing about this laser so it’s all a learning experience.But I probably still need to replace the tube I would guess?
If it wasn’t lasing, how could it mark the target?
This doesn’t make sense and your m1 image shows there is an issue…
Keep up updated on what you are experiencing. I don’t know how the Trocen is laid out as far as what settings mean what.
Good luck
I got the pulse working yesterday after I cleared the files from the controller- I was able to get the mirrors lined up. Today I had to put in power settings for 2 and it worked🤷‍♂️ - I will let you know if I run into more issues appreciate the help from everyone
